Learned a lesson today about USB cables
0 Members and 1 Guest are viewing this topic. Read 1713 times.
glynnw
  • I have tin ears.
« on: 12 Dec 2012, 07:30 pm »
Despite being a believer in the value of good analog cables, for the past 4 years I have resisted spending money on expensive USB cables, using an inexpensive Transparent Audio Labs model that I got with a DAC I purchased at some point in the past. I could hear no difference between it, a basic Wireworld model and a cheap everyday USB PC cable.  After reading the latest Absolute Sound list of products of the year, I found and purchased a used Wireworld Platinum Starlight cable.  Well, after a few hours of listening it sounds better, plain and simple.  I don't get the larger soundstage mentioned in the review, but the smoothness on vocals is sublime.  Everything just sounds a tad more real and beautiful.  I doubt if a non-audiophile would even notice the differences, but after 40 years of doing this I trust my own impressions, and this thing is a valid, if small,  improvement.  So it's another case of not understanding, but believing.  I just finished discussing this with a non-audiophile buddy who was a network engineer and spent a lot of time analyzing signals for ma bell and he thinks I am simply delusional and a bit crazy.  He's only half right.
wushuliu
Re: Learned a lesson today about USB cables
« Reply #1 on: 12 Dec 2012, 09:20 pm »
Now the next step is somehow getting things configured so that you don't need the usb cable at all, just an adapter between components. Best cable is no cable.
Elizabeth
« Reply #2 on: 12 Dec 2012, 09:33 pm »
Is that a 'theory'? Because I find yes, sometime the best cable IS a cable.
Sometimes the magic happens because of the cable. With no cable, it is just not 'there'
kyrill
« Reply #3 on: 22 Dec 2012, 11:39 pm »
yep
I heard on my system ( modified DEQX, modified JAdis tubeamps, 3 way OB speakers with Visaton B200 mid range drivers all treated with Ennemoser C37 lacquer)  the Locus Design Nucleus v2 feeding a Sonicweld diverter and the difference between that cable and a Wirewold Starlight USB cable was HUGE.. unmistakeable. I listened to this  together with Josef the lead designer of JPlay and we both confirmed the huge difference. Then I tried a 1 inch USB A-->USB B adapter and it sounded much better than the Starlight but discernible less than the Nucleus V2
A USB A male to a USB B male adapter :
« Last Edit: 23 Dec 2012, 07:27 pm by kyrill »
