Bryston Power Amps - Bridged Mono
0 Members and 1 Guest are viewing this topic. Read 1235 times.
Samurai7595
« on: 11 Dec 2012, 07:51 pm »
Looking at the specs of some of the Bryston amps, it mentions the possibility of a "Bridged Mono" connection.
For example, the Bryston 2BSST2 amp mentions:
• 100W into 8 Ohms (180W into 4 Ohms)
• 360W into 8 Ohms (Bridged Mono)
So, if using two of these in a bridged mono configuration, would these act as real mono amps, in the true sense of the word, or is it a compromise (sound-wise) when comparing to true mono amps?
Also, in a bridged mono configuration, would it support any type of speaker?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Power Amps - Bridged Mono
« Reply #1 on: 11 Dec 2012, 08:07 pm »
Hi
Yes they would be true MONO amps but so are our stereo amps because the only thing common is the power cord.
When you bridge an amplifier it 'see's' 1/2 of the impedance it does in stereo so you have to be careful that the amp does not current limit into the very low impedances.  So 4 ohms becomes 2 ohms etc.
james
