0 Members and 1 Guest are viewing this topic. Read 38262 times.
And how did the McIntoshes do with the 20.7s?
Kevin:You might be surprised and I would almost bet that you could live with the 20.7's with a mere 150wpc of tube bliss. Off the top of my head, I believe the VAC's have 3db of dynamic headroom, so they can hit 300wpc for short bursts. Then there is the way larger panels will energize the room vs the slightly smaller 3.6's that will compensate nicely. Jim
A few months after purchasing it, I confirmed the value of the VAC by swapping the X350 back into the system. At that point, I realized that the differences, though initially (and probably still) subtle, were practically indispensable – I had learned where they existed and no longer found them all that subtle.
There's only one way to find out.When I had Carvers with meters I found that most of the time I was using 50WPC or less.When I'd get carried away I'd see peaks of 150-200 but that was about my limit.
5' will be just fine, tweeters in and don't go nuts with sound deadening materials.
Well, I'll be a (fill in the blank).Sometime back Wendell took me to task over "3.7s on steroids" as I guess that the implication was just more brawn.I did a little fooling around with the preamp and phono pre earlier tonight and put on "One of These Days" from Pink Floyd's Meddle.During a slide guitar section I had a moment of panic as I thougt a tube was going haywire.Nope. It was a slide guitar passage which zipped from the bottom portion of the left speaker over to the bottom portion of the right speaker and then the guitar swirled up the right speaker. I've heard this album since it was released back in the early 70s and I've never heard that passage before as it was always buried in the mix.Increased resolution would be the phrase (along with moving a lot more air).Very impressive.Back to Meddle. The dog really hates this album, ha, ha.
Funny thing, it was several early Pink Floyd albums/cds that showed me how much I was missing, especially Atom Heart Mother. Come to think of it, there are many albums/cds that I discovered many new things on when I got my 2.5's. Jim
