Can I use a preamp with the sensation m901?
bardamu
Re: Can I use a preamp with the sensation m901?
« Reply #20 on: 28 Jul 2014, 12:23 am »
Hello Tarzan,
Did install the Russian paper in oil on the top side of the circuit and the 100nf polystyrene i am using in my other amp on the the other side. Will still have to install  the binding post at their new position, the power switch and connector too, and the xlr input as as well. All the holes are done just need to do the soldering. Will take a few hours because i want to do it better than the person who did install the caps. The solder joints did look below average.
Will probably run out of solder and my new solder other brand will arrive tuesday.
Sincere greetings, Edward
