Bryston SP3 - Infrared codes for harmony remote
0 Members and 1 Guest are viewing this topic. Read 1896 times.
ragg987
« on: 6 Dec 2012, 02:57 pm »
Finally took the plunge and got myself a SP3 (still boxed as house is getting redecorated - can't wait to plug it in).
I would like to use my Logitech Harmony to control this, however the SP3 is not in the Harmony database, and the Logitech support have asked if I can send them the "Hex-IR-Codes" so they can add it.
Does anyone know if these are available and where to get them from? Nothing in the manual, and a google search did not get me an answer...
Ritchief
Re: Bryston SP3 - Infrared codes for harmony remote
« Reply #1 on: 6 Dec 2012, 03:05 pm »
If you PM with your email address I will send you the HEX codes in excel format.
ragg987
« Reply #2 on: 6 Dec 2012, 03:54 pm »
Thanks, Ritchief - PM on the way.
Ritchief
« Reply #3 on: 6 Dec 2012, 04:05 pm »
Codes emailed to you.
ragg987
« Reply #4 on: 6 Dec 2012, 04:16 pm »
Have forwarded these to Logitech, so hopefully they can add them and others can also use them. Thanks, again.
Ritchief
« Reply #5 on: 6 Dec 2012, 04:22 pm »
No problems - Enjoy
mrJB
« Reply #6 on: 10 Dec 2012, 01:26 pm »
Hex codes!  I like hex codes!  Any chance I could have a copy to extend the life of my Universal MX-800?  Was just thinking about this yesterday.   Do you have a hex code for the main/zone buttons?? By the way, where did they come from?   Thanks.
Ritchief
« Reply #7 on: 10 Dec 2012, 09:04 pm »
mrJB - email sent you with the codes...
