ordering correct transformer
0 Members and 1 Guest are viewing this topic. Read 718 times.
wroman214
« on: 4 Dec 2012, 09:34 pm »
  I will be building a power supply for my Soundsmith phono preamp.  I am considering a couple of options.  The easiest would be to order the PS boards and components from chipamps.com and add my own transformer.  The work here is already done and I will probably build their unit. The details for the PS is here:
http://chipamp.com/images/ps-rev3-sch.gif
  They say for 24-25 volts out to use an AVEL 160VA  18 + 18 to supply a stereo amp and after regulation the voltage will go from 18 to 25 volts.
Since the Soundsmith needs 24 Volts all is good.    MY QUESTION is should I expect that much of rise in voltage if I choose to construct a different PS using similar rectifiers.  I was considering a choke filtered PS but keeping the same rectifiers.   I have contacted Hammond and asked the question and they said to expect a 10% drop in voltage, if that goes from 25 to 22.5 that is acceptable.
   Putting it differently is doing away with the 10,000uF cap after the diode bridge going to drop the voltage even further than the 25 volts I would see before the choke.  I am trying to buy the correct iron for the job.
