0 Members and 1 Guest are viewing this topic. Read 9908 times.
.What is a good choice for flooring in a basement listing room? I was considering.. a low-pile carpet in most of the room (if that's practical).All comments appreciated!
Mike, this is what I did to my entire basement floor to save valuable height but give me a cushion, small R insulating value, and easy attachment of stud walls with nails or screws w/o power nailing into concrete:Owens corning pink fanfold insulation comes in 1/4" thick x 48" x 50 feet folded in 2 foot sections. On top of that 7/16" OSB held together at the sheet edges with roofing clips.No gluing required. The weight of the OSB and friction of the fanfold holds everything in place and you just build away on top of that.
Have you thought about splaying your walls? Or going with hat channel and isolators, double drywall, and green glue?
No. But I wish I had. Next time I will go to all the extremes, even adding isolation matting.
For the floor Dricore or something like it is diy friendly and prudent if you have humidity worries. I would use (and did use) resilient channel for the ceiling. It only take 3/4 inches and is quite effective
Be sure to coat the raw concrete with Drylok before laying down anything else to prevent mold growing on the concrete and keep the humidity down. It kills that cold basement feeling and smell.A friend has a concrete floor in his listening room with a resilient plastic layer then special strand board sheet, then pad and carpet. It is very comfy, and his room sounds great. He did a lot of research, so I can get the details if you want. Rich (also in NC )
Hmmm . . . . so the sound channel, etc., didn't provide sufficient isolation? I am working with an acoustician, but when I suggest any "belt and suspenders" approach, he is dubious.
Thanks! Dricore looks good. Interesting about the channel. The clips & channel recommended to me seem to be thicker.
Dricore is expensive and probably over an inch on height. The OC and OSB will chew up about 3/4".
Delta-FL subfloor material, taped together with Tyvek tape.
Regarding the resilient channel, been using that for a long time.....it gives a rating of down 10-11db, its esay and cheap, and is used for theatres....heres a 176 seat I have been working on. You can see the res bar in the photo.Double 5/8"drywall, screwed to the res bar.
