Room w/ low ceiling -- worth building?
0 Members and 1 Guest are viewing this topic. Read 4922 times.
Mike-48
« on: 3 Dec 2012, 05:17 am »
The only place to build a listening room in our (urban) house is the basement. After planning an acoustically isolated room, I'm wondering if it's worth building, given the dimensions. The height especially is far less than ideal.
I would truly appreciate comments from those with similar-sized rooms . . . have they worked out for you?
Width:   ~ 12 ft 10 in (=3.9 m)
Height:  ~ 6 ft 10 in ft (=2.1 m)
Length:  up to 22 ft (=6.7 m) (will be decided after height and width are known exactly.)
jimdgoulding
Re: Room w/ low ceiling -- worth building?
« Reply #1 on: 3 Dec 2012, 05:56 am »
I really don't know myself, but you're in the right place.  I would think that if your speakers of choice are foward firing radiators like Maggies, etc, your low ceiling may not be all that much of an issue :dunno:.  But, there are guys wiser than me about such things and you should be hearing from them very shortly.
« Reply #2 on: 3 Dec 2012, 08:23 am »
Perhaps you can keep the speakers/furniture low.  My 8ft x 13ft x 22ft room is wonderful, your's wouldn't be all that much smaller.  Those (golden Greek/Cardas) ratios are about the biggest for a limiting ceilng height you'll find recommended.
Make sure you insulate every wall/ceiling (staggered stud walls, don't even try recessed can fixtures), even the ductwork (lined fiberglass can barely hear the furnace) and door (exterior fiberglass has stainable wood grain).  And "float" the ceiling by running gauge metal furring strips opposite the joists above to isolate it from the floor above (alternate is Green Glue with another layer of drywall, haven't tried it but you'll lose a bit more ceiling height).
My mistake was the recessed cans (and the builder not agreeing to the furring strips).  Otherwise the room is spooky quiet.
django11
  • Canuckistani
« Reply #3 on: 3 Dec 2012, 11:39 am »
My room is in a basement. About 16 by 16 with the height around 87 inches.  Floors are ceramic on slab  :nono:.  Sounds fine.  Terrific with with room treatments.
« Reply #4 on: 3 Dec 2012, 12:39 pm »
Since it is the only place you have and you want a dedicated space go for it.
cheap-Jack
« Reply #5 on: 3 Dec 2012, 02:32 pm »
Hi.
Height:  ~ 6 ft 10 in ft (=2.1 m)Length:  up to 22 ft (=6.7 m) (will be decided after height and width are known exactly.)
Mine is also in the basement with drop ceiling (made up of suspended standard 2x4ft glasswool panels). Clearance is only 7ft (=2.14m) from the wall-to-wall carpetted concrete basement floor. Acoustically fine even for reproducing 20Hz subsonic pipe organ music.
Question: Is yr basement ceiling finished? If yes, what is it?
c-J
cheap-Jack
« Reply #6 on: 3 Dec 2012, 02:43 pm »
Hi.
Right, never get any sound reflective flooring, e.g. ceremic/stone like tiles. :nono:
c-J
Ethan Winer
  • Audio expert
« Reply #7 on: 3 Dec 2012, 04:34 pm »
You can definitely make a room that size sound good. The key is to add absorption on the ceiling. If you think about it, a ceiling that's totally absorbent is acoustically the same as a ceiling that's infinitely high. Either way, sound goes up and never comes back down. Those dimensions as listed are not bad, though you'll need bass traps and other acoustic treatment. If the width and height are not exactly as shown, my Graphical Mode Calculator program and article will help you identify the best length.
--Ethan
Mike-48
« Reply #8 on: 4 Dec 2012, 09:23 am »
Thanks to all for the comments. The plan is to use sound-isolation channel for the walls, and two layers of quietrock for the ceiling (takes less height than channel).
No cans in ceiling! Only floor lamps.  Probably will put hvac vents in walls to maximize isolation overhead.
jimdgoulding
« Reply #9 on: 4 Dec 2012, 12:20 pm »
Hey fellas, what about just taking the drop down tiles out altogether?
Mike-48
« Reply #10 on: 4 Dec 2012, 05:47 pm »
Jim, there are no ceiling tiles in the room. It's the (concrete) floor and joists above that limit the height.
jimdgoulding
« Reply #11 on: 4 Dec 2012, 09:52 pm »
Gotcha, Mike.
Rob Babcock
« Reply #12 on: 5 Dec 2012, 07:13 am »
I had a very similar room (basement) six or seven years ago and the sound was very good once I had a bit of treatment done.
Ethan Winer
  • Audio expert
« Reply #13 on: 5 Dec 2012, 04:51 pm »
In that case, line the spaces between the joists with 12-inch thick R-38 fluffy fiberglass, or whatever thickness is appropriate if the joists are less than 12 inches from bottom to top. Then you can cover that with soft fabric for appearance.
--Ethan
Mike-48
« Reply #14 on: 5 Dec 2012, 06:11 pm »
--Ethan
Ethan, that is a nice idea for absorption, but for reduction of transmitted sounds above, I'll need to use sheetrock with some kind of special construction. If the room upstairs were empty, what you suggest would be ideal.
P.S. What's your cat's name?
Mike-48
« Reply #15 on: 5 Dec 2012, 06:11 pm »
Thanks -- that's good to know.
shadowlight
« Reply #16 on: 5 Dec 2012, 07:18 pm »
I room is similar where the ceiling height varies between 6' 10" to about 8' and the width is around 12 1/2' with length around 30'.  It sounds pretty good to me as a multipurpose room.
Here is one picture of the room.  The center is pretty much 6' 10".
Ethan Winer
  • Audio expert
« Reply #17 on: 6 Dec 2012, 05:01 pm »
Ah yes, you mentioned the need for isolation. In that case you'll need to add absorption under the finished ceiling to "make it go away."
That's my boy Noah.
