The last time I tried this, I didn't get too many responses, so I'm going to try again.
I'm looking for new speakers. At least, I want the mains and center channel. My equipment is:
Odyssey stratos monos for the front three channels
Odyssey Tempest Preamp
Cary 303/200 CDP
Denon 4800 processor
B&K ST2140 for surrounds
Pioneer DV47a DVDP
Some things I'm looking for:
3D, enveloping effect
Detail and clarity without being too dry
Rich, full sound
Good impact
Non fatiguing
Quick
Transparent
Realistic sounding
Good, clean, deep, bass
Placement flexibility
50/50 for 2ch and HT
Matching center and surrounds
What I definately don't want:
Speakers to come too far out from front wall. Less than a foot is preferable, and absolutely no more than 2'.
Unstable speakers
Dry
Fatiguing
The type of music I like is:
Jazz
rock
alternative
punk
hip hop
female vocalists
My room description is:
14 x 15 x 8
Front wall has 55" tv pushed flush into a modified closet
2ch gear on short stands in front of tv
Right wall has large sliding glass door
Front half of left wall opens up to split level above
My 11' couch is about 2-3' from the back wall
I have a bass peak at 40Hz and dip at 55-60Hz
Listening position:
Regular postion is about 33" high and around 9-10' from the mains.
I don't walk around and listen, but I do listen to music in the back yard, outside the sliding glass door.
The main options right now:
Selah RC3 (with Seas mag woof, morel mid, Fountek ribbon tweeter) plus two whomp subwoofers and Sardonyx center channel containg the same drivers as the RC3
or
VMPS RM30M mains with either the LRC or RM30C for the center
Here's some of the pros and cons I've come up with:
Pros of VMPS:
Supossedly really clean articulate mids which a plus for HT
Very fast, detailed, and transparent
Bipole available for surrounds
Bass, mids, and treble are all adjustable *A BIG PLUS*
Asthetics
Lots of options
Cons of VMPS:
Lots of options
Listening height *THE BIGGY*
Will have to reconfigure racks to accomodate large center
Gets expensive will some of the options
Cherry veneer costs a lot
Pros of Selah:
Different configurations to choose from. Sub/stand mount system can optimize placement
Stereo subs
Center channel would fit perfectly in my system
Standmount height can be perfect for my listening height
Cons of Selah:
Absolutely no reviews or feedback of the Seas design. Decision is totally blind
Trying to get subs to integrate well will standmounts
Have to buy stands
Both have free trials, but don't want to try both at once because return shipping can be expensive. I really want these to be the last speakers I'll want for a long time. I came up with these two companies because:
Both have a free trial
Reputation through this site and PMs I've received
Description of the type of sound they provide
I know I should listen and I know it comes down to personal preference, but which would you choose considering the information I've given and experience you've had with either or both.
Any others to consider?
