Question about power supply caps
0 Members and 1 Guest are viewing this topic. Read 1011 times.
TimS
« on: 1 Dec 2012, 01:50 am »
Hi
I'm building a amp and already have four of 63V 10,000uF caps that I will use.  I need to buy four more for the amp but I want to increase the total capacitance.
As the BOM only requires the caps to be 40V - is it OK to buy four more (of the same make/type) but at 40V 33,000uF and mix these (equally between channels) with the 63V 10,000uF I've already got?
I'm thinking it will be OK but wanted to check.
Speedskater
  • Kevin
Re: Question about power supply caps
« Reply #1 on: 1 Dec 2012, 01:39 pm »
Well probably, the manufactures do add a safety factor.  But you will always have that small nagging doubt and they may not last as long as the 63V units.
TimS
« Reply #2 on: 1 Dec 2012, 07:57 pm »
Thanks for the reply.  The BOM has the specified that the caps are 40V only so the ones I'm looking at (to buy) should be OK.
Tim
