0 Members and 1 Guest are viewing this topic. Read 5346 times.
You heard a SUT + MM stage + LOMC better than a MM stage + MM cart but a different combination may give different result.
Well, my experiences haven't been so cut and dried. While the SUTs I tried out were quieter and the top end a bit less hot, I felt there was a loss in dynamics, and ultimately, felt that treble and bass extension were truncated. Although I have to say the best of the ones I tried were very easy on the ears, but almost overly smooth.
I heard the same cart with and without the SUT on my MM/MC phono stage.
Like anything else in vinyl, the SUT has to be matched with the cartridge and the phono stage itself. My cartridge has a very low .22mv output, and my phono stage is a MM type, so I must step it up. I use a Hagerman Piccolo head amp set at its highest 26db gain. All is good, but I am curious about trying a custom designed and built SUT to hear what the difference could be. Looking into the Slagels.
