IPAD APP for BDP1/BDA1 for basic controls?
0 Members and 1 Guest are viewing this topic. Read 1765 times.
Heckler75
« on: 29 Nov 2012, 03:56 am »
is there  a  Ipad App,  that can do basic functions, for the BDP1/BDA1 .
that can power up, change inputs on BDA (aes/ebu or bnc  etc...)
mostly looking for basic functions  on both.
any good App available    and EASY  to use.
or  is  the BR2  remote  my only option?
 :oops:
Xinon
Re: IPAD APP for BDP1/BDA1 for basic controls?
« Reply #1 on: 29 Nov 2012, 08:29 pm »
I would love that .
I hate to Get out of the chair to change input on the Bda1 :duh:
« Last Edit: 30 Nov 2012, 05:24 am by Xinon »
unincognito
    • bryston.com
« Reply #2 on: 6 Dec 2012, 03:15 am »
That functionality has been expressed by others and is being looked into
Chris
Heckler75
« Reply #3 on: 6 Dec 2012, 03:53 am »
Chris
that would be awesome. :thumb:
a Bryston app (ipad)   would be  a great app for basic controls  for BDP1/BDA1
i would  gladly pay, for a  App, i'm sure  most would agree...   :thumb:
skunark
« Reply #4 on: 6 Dec 2012, 04:19 am »
It would be even more interesting for Bryston to provide the complete iOS/Andriod solution to control the BDP, BDA, SP3, BP26, etc.    Either use the existing RS-232 port on the BDP or better yet an USB IR blaster to control a pre-amp and other devices as well.
Naim has a killer solution for their Uniti line that controls the pre-amp, tuner, etc, but since they are all-in-one cd/fm/thumbdrive/streamer device, much easier task if it's all in one device.
Alpha10
« Reply #5 on: 6 Dec 2012, 06:26 am »
+1. This would be brilliant   :thumb: :thumb:
Cheers
unincognito
    • bryston.com
« Reply #6 on: 11 Dec 2012, 03:58 am »
All options are being looked into; however currently has low priority
skunark
« Reply #7 on: 11 Dec 2012, 05:32 am »
Hopefully this moves closer to the front seat someday, I think a lot of companies under estimate convenience features which translate to better cabinet installations.
Also I would love to see Bryston select one type of 12 volt trigger such that you can daisy chain them.   Any reason why the 2 wire approach was selected vs the much more common mini-jack cable?   It's also seems a bit inconstant.
Jim
