Industry Circles
GR Research
Danny Richie
Thread size on Super V feet
0 Members and 1 Guest are viewing this topic. Read 1390 times.
MichaelHiFi
27 Nov 2012, 09:31 pm »
The inserts on the Super V bases are what looks to me 5/16" thread. Is that correct? Wish to get some fancy gliders for these speakers. They're too heavy for spikes is you're prone to move them around much.
Danny Richie
Facilitator
Re: Thread size on Super V feet
27 Nov 2012, 09:33 pm »
I went to the hardware store years ago with a few of those inserts and picked up a few bolts that fit them that I use for driving them in.
I don't recall the size but do remember them being a metric size.
Austin08
Reply #2 on:
27 Nov 2012, 09:52 pm »
If you said it looks like 5/16 and Dan said it metric then the closest match is M8.
Ed VB
Reply #3 on:
27 Nov 2012, 11:46 pm »
This company should have whatever you are looking for. I ordered a sample at no cost so worth checking out.
http://www.ezlok.com/Home/index.html
stevenkelby
Adelaide, South Australia
Reply #4 on:
28 Nov 2012, 03:23 am »
I'm not sure what the thread size is but I hot glued gliders to the spike feet so I can slide the speakers over carpet or tiles easily.
Steve.
MichaelHiFi
Reply #5 on:
29 Nov 2012, 03:26 pm »
I confirmed with a 8mm metric bolt. It is 8mm.
Thanks for your help gentlemen
Industry Circles
GR Research
Danny Richie
