0 Members and 1 Guest are viewing this topic. Read 1761 times.
James what would be the best gain setting( 4bsst2 pro) to match my BP25?
Do they even have the 1 or 2 volt settings on the pros. I thought they were variable dial on the back?
There is no 'setting' as such - just go with what sounds best. All you are doing is adjusting the 'sensitivity' of the input for 1 volt to 2 volts.james
