best upgrade to rockets to improve dialog clarity?
0 Members and 1 Guest are viewing this topic. Read 18114 times.
Early B.
Re: best upgrade to rockets to improve dialog clarity?
« Reply #40 on: 1 Dec 2012, 12:30 am »
judging by the silence...i wasn't even close :lol:
Oh, you're close. In fact, it may be less than your estimate if you can find a friend or co-worker who has basic soldering skills to do it for you in return for a 6-pack or something. Jot down the values indicated on the caps and resistors and email them to Danny Richie so you can be assured to purchase the correct items.
minisq
« Reply #41 on: 1 Dec 2012, 02:07 am »
i have build dozens of crossovers...and yes i could plop down my cash and order some caps and coils and solder them together. In fact i built my center channel using Danny's kit. Along with many many crossovers for peoples car audio installs and my own.
But in this case i was looking for a turnkey solution so that i would just "know" they were done perfectly. Problem i see though, is the inductors have no values printed on them...so some research would need to be done, or i mail all 3 pieces from one speaker to Danny for measuring.
Early B.
« Reply #42 on: 1 Dec 2012, 03:26 am »
Oh, I was assuming you'd keep the stock inductors. They're not ideal, but you may travel beyond your budget if you want a turnkey solution for a complete crossover makeover. Sonicaps for replacing the 15uF caps will blow through one-third of your budget estimate.
HAL
« Reply #43 on: 1 Dec 2012, 03:30 am »
You might also consider the Skiing Ninja upgrades for crossovers.
http://www.skiingninja.com/
Sean might have run into Swans speakers in the past.
Just a thought.
minisq
« Reply #44 on: 1 Dec 2012, 02:22 pm »
i may need to keep the stock inductors, as i cant easily identify them. As for sonicaps...yes they are expensive, and i used them in the past and loved them, but i am open to going with "second best" here if needed.
Danny Richie
« Reply #45 on: 3 Dec 2012, 12:59 am »
That would not be a problem.
Those things are iron core slugs. I'd replace them with a good air core inductor. That will be a very nice improvement.
If you want to save a few bucks I can get you some good poly caps from Erse that are pretty inexpensive. Then just by-pass them with a .1uF 200 VDC Sonicap. Those small by-pass caps are only $2.70 each.
nguyenphananh
« Reply #46 on: 21 Mar 2021, 11:54 pm »
Hi, I know this thread is antic ... Anyway, Im looking for a set of UPGRADED CROSSOVER for the Onix Rocket RS 750 and RS 200 (center channel).  They also known as "skiing ninja" crossover for this speaker, or any "upgrade/update" version of this speaker's crossover.  If anybody have these crossovers laying around... please let me know.  You can email me directly at nguyenphananh @ hotmail.  Thank you
Danny Richie
« Reply #47 on: 24 Mar 2021, 02:11 pm »
Shoot me an email about this. I can fix you up.
nguyenphananh
« Reply #48 on: 25 Mar 2021, 12:51 am »
PM. Thanks
ouldsmobile
« Reply #49 on: 15 May 2021, 07:50 pm »
Hey Danny,
I am also looking to possibly repair, replace or upgrade my crossovers in my now pretty old Rockets. I have the Bigfoot RS200 and 550's. I haven't opened them to see how the original crossovers are doing, but my receiver keeps thinking one is out of phase even though wiring is correct. Not sure if that could be a crossover issue or something else. Also my center has been sounding muddy and hard to hear dialogue at times. Used to be crystal clear.
Any suggestions?
Thanks.
Kevin
Danny Richie
« Reply #50 on: 19 May 2021, 01:48 am »
Hey Danny,
Any suggestions?
Thanks.
Kevin
I designed upgrades for those models that went into the later production runs.
And there are upgrades that can be done to the upgraded ones as well.
Send me crossover pics and I'll know which ones you have and what can be done to them.
nguyenphananh
« Reply #51 on: 19 May 2021, 05:17 pm »
Hi Danny
I have a question for you.  Like I mentioned about,  I found my RS750 to be muddy, not clear, not musical, some frequencies are muted or deleted, the sound field is NARROW focus..etc...  I found the Monitor Audio Silver series tower speakers sound to be amazing, smooth, musical, WIDE OPEN, detail...  I really like this type of sound.  My question is whether with the upgraded Ninja Skiing crossover designed by you, can the RS750's sound quality be any where near the Monitor Audio speaker's?? or would it be limited by the driver, cabinet designed?
Also from our previous conversation... I wasnt clear whether your design was a completed new/different pcb, or was it a upgraded capacitors, resistors??.  Like I stated earlier, I am not capable to assemble a completely new pcb board from components....  but Im more than capable of replacing the existing pcb with better/upgrading caps and resistors.  Please let me know.
Im also interested in upgrading the components for the center RS200, if that is what you are offering... so please be more specific on this.  Thank you
Danny Richie
« Reply #52 on: 25 May 2021, 01:25 pm »
Hi Danny
Yes, that is about the way they sounded.
My upgrade fixed all of that.
I think I also answered your email that was this same post. I sent before and after measurements too. I hope you got it.
ouldsmobile
« Reply #53 on: 30 May 2021, 06:06 pm »
Hey Danny,
EDIT: PM Sent with pics
Thanks, I will try to get a pic of both the RS550 and RSC200 in the next few days, I believe mine are the originals but could be mistaken. I am busy with a 9 week old puppy but will get some pics during one of his naps.  :lol:
Thanks again,
Kevin
« Last Edit: 1 Jun 2021, 12:25 pm by ouldsmobile »
