ob5/ob7 question
0 Members and 1 Guest are viewing this topic. Read 1320 times.
ricardojoa
ob5/ob7 question
« on: 18 Nov 2012, 09:47 am »
Hi,
the open baffle on the ob5 looks different then the usual one i have seen, as these have the opening on the side. Do these still require lots of room behind them ? How much space do i need from the side? In addition, can the OB7 built like the ob5 with a closed back, open sides?
Are there anyone who would built these professionally that you know of, as i for sure wont be able to built these.
Thank you
« Last Edit: 18 Nov 2012, 03:18 pm by ricardojoa »
ricardojoa
Re: ob5/ob7 question
« Reply #1 on: 20 Nov 2012, 01:20 pm »
Hi Danny i thought you might hvae missed this post so im giving a bump to it.
Danny Richie
    • http://www.gr-research.com
« Reply #2 on: 20 Nov 2012, 04:54 pm »
An early version was done with a top and back panel (lined with foam) to make it look more like a typical boxed speaker.
It was kind of a smaller version of the OB-7 Plus.
But it sounded better with it completely open.
See this one built by Ronnie:
