Cheap crossover tweak
0 Members and 1 Guest are viewing this topic. Read 1281 times.
WireNut
« on: 17 Nov 2012, 07:35 pm »
 Cheap crossover tweak.
 I recently soldered a 0.01uf Vishay MKP 1837 cap ($1.00 each) in parallel across a 5.6uf silver/gold/oil cap
that is just before my tweeter and found that stick definition on cymbals and brushes on snare drums are much
better defined in my system.
WireNut
Re: Cheap crossover tweak
« Reply #1 on: 19 Nov 2012, 04:10 am »
 I wonder if I could use Audio Notes Tantalum 2 Watt resistors in my passive crossovers which
may sound better then the 10 watt resisters that I'm currently using.
Or would 2 watts not be high enough and fry?
*Scotty*
« Reply #2 on: 19 Nov 2012, 05:02 am »
You should probably seek to use resistors that equal the power rating of original component. Where are the resistors located in the circuit? Are they in-line with a driver or are they in a shunt position? The resistors in series with a driver are more critical.
Mills makes a line of non-inductive resistors with ratings up to 12 watts.
See link,  http://www.soniccraft.com/mills_resistors.htm
Scotty
