Need help finding power cord termination adaptor
0 Members and 1 Guest are viewing this topic. Read 1678 times.
djbnh
« on: 16 Nov 2012, 11:01 pm »
I have an 15A aftermarket power cord that has the typical three prong IEC audio power amp US termination (IEC C15).
However, I'd like to use this power cord on a Denon AV amp, which looks like it requires a two prong IEC  C17 termination.
Can anyone point me to an adaptor that I could use? Thanks for your help.
~edited - pics of terminations added
Early B.
Re: Need help finding power cord termination adaptor
« Reply #1 on: 16 Nov 2012, 11:11 pm »
Here:  http://www.amazon.com/Pangea-IEC-C7-Adapter-Standard/dp/B003K1K71I/ref=sr_1_1?ie=UTF8&qid=1353107345&sr=8-1&keywords=c7+adapter
You can also purchase it directly from Audio Advisor.
I have one I can send you. PM me if interested.
djbnh
« Reply #2 on: 16 Nov 2012, 11:14 pm »
Thanks, but that's not the right one, look at this:
Occam
« Reply #3 on: 16 Nov 2012, 11:20 pm »
You're good to go. Your standard c13/15 IEC on your cord will fit the IEC C18 inlet  on your Denon just fine. The Denon's inlet just doesn't have the safety ground blade to go into the C13/15's safety ground slot.
EDIT: for reference - http://en.wikipedia.org/wiki/IEC_60320
« Last Edit: 17 Nov 2012, 01:01 am by Occam »
djbnh
« Reply #4 on: 18 Nov 2012, 10:40 am »
Works, thank you.
« Last Edit: 20 Nov 2012, 11:38 pm by djbnh »
