Subwoofer Placement
0 Members and 1 Guest are viewing this topic. Read 1128 times.
riverrat373
Subwoofer Placement
« on: 15 Nov 2012, 11:55 pm »
How critical is subwoofer placement? I have a small living room and about the only place I have for the subwoofer I just purchased is behind and slightly to the right of my right speaker, in the corner.  :scratch:
medium jim
Re: Subwoofer Placement
« Reply #1 on: 16 Nov 2012, 04:32 am »
Can be critical depending on the room.   The important factor is if you like the way it sounds and is well integrated with the main speakers.
Jim
