FS: Burson 160D DAC/Preamp/Headphone Amp
0 Members and 1 Guest are viewing this topic. Read 2619 times.
sfig
« on: 15 Nov 2012, 11:06 pm »
**SOLD**
I ran this as my high resolution DAC (with both USB and S/PDIF inputs) but it's really a 3 in 1 when you add in its highly rated capabilities as a preamp and a headphone amp (with outputs for both high or low gain headphones) as well.   6moons gave it their Blue Moon award.  It's in great condition with everything working as it should (rated 8 of 10) and includes the original box and packaging.  Selling it for $sold INCLUDING shipping to your door in CONUS.
Here are the specs....
Burson Audio HA-160D Headphone Amplifier Specifications
Input impedance: 47 KOhms
Frequency response: 5Hz (-0.3dB) to 35 kHz (-1dB)
Signal to noise ratio: >98dB at 0dB gain
THD: <0.001% at 6mW/300 Ohms
Channel separation: >70dB/10kHz
Output power: 650mW/300 Ohms, 800mW/60 Ohms
Output impedance: line out 60 Ohms, phones out 5 Ohms
Power dissipation: <25W, internal, regulated power supply
Dimensions: 265 mm x 250 mm x 80 mm
Connectors
Inputs:
1 x USB Connection (Support up to 24bit @ 96Khz with 10ppm low jitter clock)
1 x Coaxial RCA (Support up to 24bit @ 192Khz)
3 x gold plated RCA (line level input)
Outputs
2 x headphone jacks 6.35mm
1 x pre -out with 10Db gain
and here are the pics....
« Last Edit: 20 Jan 2013, 01:37 am by sfig »
sfig
Re: FS: Burson 160D DAC/Preamp/Headphone Amp: PRICE REDUCTION
« Reply #1 on: 20 Nov 2012, 08:43 pm »
Price reduced to $750 including shipping to your door in CONUS
« Last Edit: 5 Jan 2013, 07:32 pm by sfig »
sfig
« Reply #2 on: 27 Nov 2012, 05:06 am »
Price reduced to $sold including shipping to your door in CONUS
« Reply #3 on: 23 Dec 2012, 05:13 am »
Do you still have it?
sfig
« Reply #4 on: 23 Dec 2012, 03:10 pm »
The Burson 160D is still for sale.
PaulFolbrecht
« Reply #5 on: 24 Dec 2012, 05:02 am »
Wanted to chime in that I just got one of these things (used).  After playing for a couple days it is totally amazing with my Sennheiser 600s.  I mean it may be the best headphone setup I have ever heard.  It also somehow manages to make some edgy redbook recordings (like Blakey at Birdland) very listenable but still very detailed.  This thing has greatly exceeded my expectations.
« Reply #6 on: 24 Dec 2012, 05:58 am »
Is 0.25 watts enough power?
PaulFolbrecht
« Reply #7 on: 24 Dec 2012, 06:02 am »
Sure seems to be.  Can play louder than I care to listen with no obvious distortion.
It really can only put out 250 mW?  It's built like a little tank (which is a bit of a contradiction in terms, isn't it?)
sfig
« Reply #8 on: 5 Jan 2013, 07:30 pm »
BUMP
$750 including shipping to your door in CONUS.
sfig
« Reply #9 on: 20 Jan 2013, 01:38 am »
SOLD on that other site a few minutes after listing it.......go figure
