Adding remote kit to Jolida 302b
0 Members and 1 Guest are viewing this topic. Read 1558 times.
danska
« on: 15 Nov 2012, 12:43 am »
Curious to know if anyone has used one of the Dantimax remote kits to add a volume control to an amp similar to my 302b. I'm familiar with soldering and have built a Bottlehead headphone amp, so I'm comfortable with doing some of this type of work. In my current set-up a remote would make my life much more simple so I'm tempted to find out more. I'm only looking for volume control, do I need to drill a hole for the IR sensor? Any advice would be greatly appreciated. Thanks!
Happy to supply some pictures if that helps. My amp has been modified quite a bit, caps, resistors, extra input, fixed/variable outputs. Swapping out the bias resistors to run KT88s here soon also.
