0 Members and 1 Guest are viewing this topic. Read 4443 times.
That would be incorrect. You could not possibly cut any pieces of deadening material, place them in strategic locations and not affect the balance of the platter. You simply can't be that accurate. The end result is that your table's drive is going to constantly correct it's speed every few milliseconds and that will F up the whole rhythm/pace/bla, bla, bla scenario ......Wayner
Wayner, Great point. What is your view on how periphery rings and center weights affect the platter? I figure since a number of manufacturers sell this, notably VPI, that it should not effect the balance of the platter since it's equal on all sides, yes?Thank you,Anand.
As long as it's properly machined it cannot and will not affect the balance.
if your machine is built like a BSH.
However, many older platters were cast and casting uniformity can be a problem. That means that while the outside may be within close tolerances, the consistency of the casting may very (internal bubbles, etc.) that will throw the weight out of balance. Just as even new tires and rims need to be balanced on your car, so do platters.Empire was one older company that claimed exceptional platter balance, especially in the early days with models such as the 208/298. They had secrets how to do it consistently correct.It's probably not a problem with most new acrylic platters.....Wayner
