0 Members and 1 Guest are viewing this topic. Read 14060 times.
I was thinking just this while looking over the Hypex plate amps. I'm kind of curious to see if you could pull off your DEQX magic with those plate amps. Also, no interconnects, just digital into both channels. It could be very pretty indeed. If you can pull it off I would be interested in an upgrade of the Mejors to a full active setup using the Hypex system.
Much of "high-end" audio is going nowhere because of backward thinking.
Yes, but I wouldn't limit it to lack of DSP.
Too much is focused on things that make little or no difference in sound quality.
One idea I have is a hybrid passive/DSP with a KEF Q100 concentric driver and a 7" or 8" woofer. Similar to the Soundfield design but with no extra amplification needed, more refined mids, and better driver integration. Thoughts?
I think it would be a great product if the solution can be implement simple enough that typical consumer can use it without going through lengthly process for calibration. I love the idea of not having a passive crossover inside the speaker for the potential of much better sound but had reverted back to passive amping in the past due to the following issues that I ran into:a) Active ampling without proper calibration to compensate for things such as BSC could result in inferior sound. I tried this many years ago with the nOrh Multiamp and reverted back to passive amping after 3 months.b) With the amplification is now embedded inside the speaker cabinet, I am concerned with the cabinet vibration with could affect the amp reliability in the long run.c) Intergrating the amp with the speaker also restrict the ability to upgrade to better amp. as time goes on.d) Calibration complication will also limit the usage especially over time since I tend to forget the proper steps to set the system up correctly at much later time.The above are my initial thought and not neccessary apply to what you have in mind.
assuming that the end user knows what he is dealing with the dsp.I think a member uin AH had problem with the kef cocentric driver, where the edges are tearing apart from the cone or something like that.
As noted in another post all of the DSP can be loaded here before the speaker ships so it makes it easy for the end user. Can you point to a post on the KEF driver problem? That would be an excursion issue which indicates no high pass filter on the woofer portion on the concentric driver. With my proposed design that wouldn't be an issue since the concentric would be relieved of the lower bass range.
http://forums.audioholics.com/forums/loudspeakers/82396-kef-uni-q-de-bonding-issues.html
I see - not a surround issue. Looks like that was a simple mounting problem and not the driver itself.
