0 Members and 1 Guest are viewing this topic. Read 5269 times.
Couldn't agree more. I connect my 650's or D7000's to that Woo WA6 and pull the lever on the recliner. It's hard to get back up and re-engage.Hibuck....
I have a pair of Fostex T50RP that are going to get modified during the Turkey Holidays.
I love my 650's, but eclein continues to lure me to the dark side (planar-magnetic) cans.I have a pair of Fostex T50RP that are going to get modified during the Turkey Holidays.
Hi hibuckhobby and all Audio Circle members.You own and you are using what I am dreaming of and that is the WOO WA6 and the Senheiser HD-650.If you don't mind telling me in simple words, how would you describe the sound out of that combo?Guy 13
Hello Guy...The short answer is wonderful. The longer answer is: It depends heavily on the tubes you are using.I am currently using a Sophia 274b as the rectifier and some NOS RCA 6DE7's as driver/power tubes.Once fully warmed up, the sound is both detailed and smooth at the same time. It is ever so slightlyforward in the upper midrange, but not enough to sound harsh. The bass is deep and tight althoughthere is still a upper bass 'bump' that is more a function of the phones than of the amplifier.I recently picked up some HD700's, which are a step up both in terms of detail and soundstage, butare more revealing of flaws in the recordings as well. I have owned three pair of orthodynamic cansand have decided they are not for me. What they do well, they are simply marvelous at. They requirehowever, the best source equipment and material to really shine.The WA6 as it is currently set up, is for me...excellent with both my Denon D7000's and the Senn. HD650's.I don't see myself replace it anytime soon. I bought all of them on the used market, so did save 'some' money, but it is still not an inexpensive hobby.regards,Hibuck....
I have had the HE5LE's (pretty bright), the HE500's (still a bit bright for me) I have an acute sensitivityto forward upper midrange/lower treble. I tried the LCD-2 REV. 1 and it was pretty close to ideal for me, but at the time I didn't have the Woo WA6, which probably would have been wonderful withthem. As you know, this is a hobby where personal preference really comes to the forefront, soYMMV,Hibuck....
Guy13,I think you will find that it is largely a myth that the 650s don't have good detail. I had their "uncle" the 580s back in the day and it was a very detailed headphone, without sounding "etched" or "bright" like so many more recent designs do. Not sure how that would "synergize" with a tube front end but you never know until you try. My 555's go to a whole 'nother level once you get the high frequency balance dialed in.
Guy, I think you will be very pleased with a HD650 and WA3 combination. My only advice is this:1. Give them both time to break in a bit because the sound will change a little . (for the better)2. Stop looking at reviews for other combinations. I say this because it is what I did'not' do, and the result was constant buying of other things in the hope of improving my setup.I did achieve my desired result, but at a much greater cost than I had in mind at the outset. best,Hibuck.....QuoteHi hibuckhobby and all Audio Circle members.Thanks for the advice, it will do what you have recommended, not because you are the voice of God,but because your recommendations makes lots of sense.The Woo WA3 and the HD-650 is exactly within my budget for the amplifier/ headphones combo.I hope the HD-650 will not be discontinued before I reach the bottom of my pocket, which should be early or at the latest middle of 2013.Thanks again.Guy 13
HD650 is very good. LCD-2 is not far ahead, but its sound signature is quite pleasant. for comfort i think LCD-2 is far ahead than HD650
Guy, I think you will be very pleased with a HD650 and WA3 combination. My only advice is this:1. Give them both time to break in a bit because the sound will change a little . (for the better)2. Stop looking at reviews for other combinations. I say this because it is what I did'not' do, and the result was constant buying of other things in the hope of improving my setup.I did achieve my desired result, but at a much greater cost than I had in mind at the outset. best,Hibuck.....QuoteHi hibuckhobby and all Audio Circle members.Thanks for the advice, I did spend lots of hard earned money on audio stuff in thelast 40 years and now that I am getting close to 65 years old, money is more difficultto earn.Also, I am a little tired to look around for the best money/quality ratio. (In USA you say : Bang for the buck.I want this audio combo to be my last one and not get tired of it in a few years from now.Thanks again for the advice.Guy 13
