0 Members and 1 Guest are viewing this topic. Read 18236 times.
Back when I used NAS at home, quite a few manufacturers included iTunes Server (the precursor to Airplay) as part of the NAS' firmware. While it seemed to work ok, updates to iTunes Server by Apple were slow to trickle down to each manufacturers individual updates. Some didn't even bother.
Why do you not use one anymore?
A dedicated Mac with attached storage is more powerful and almost cheaper than a NAS equivalent for its intended purpose, IMO.
Are you guys talking about using airplay without a computer?
What about using the Synology without the airplay and as a straight forward NAS/external HD?
Regarding back up: I was thinking of using the Synology as a house wide database server and backing up pictures on one single drive and music on another single drive and videos... etc...
It would also be cool if I could use airplay for streaming to my back deck system or other noncritical zones. Don't know if you can do a blend of iTunes and airplay. So... use my iTunes library on the big rig and utilize airplay streaming internet radio and MOG by the pool.
Wondering if sound quality will take a hit (on the big rig) and if you can do a blend of the services or if it's even necessary. Still a little fuzzy on all this.
Although I only have a single drive model, I don't see any option for directing a particular backup set to a particular drive, unless each is originating from a different computer with it's own instance of backup software. It may be possible with third party backup software, but it doesn't look like a possibility with the included Synology Data Replicator 3 software.
If you relied on the Synology Data Replicator 3 software, what would you back up to? I think I know the answer which sounds prohibitively expensive.
Not sure I understand the exact question
Price breakdown:Synology DiskStation DS412+........ $650One 4TB 2.5" drive........................ $235One 2 TB External HD for Back Up.... $190Total Costs.................................. .. $ 1,075
I'm still a bit undecided about the whole NAS thing. In the end, it seems like it's easier and cheaper to string Firewire drives. Assuming that noise isn't an issue.
