LS-9 in Denmark
0 Members and 1 Guest are viewing this topic. Read 2445 times.
tubesaab
LS-9 in Denmark
« on: 11 Nov 2012, 06:27 pm »
Hello
i.am new on this circle..Can you please tell me,,are there an LS-9 owner in Denmark
will be happy to listen to one
best regards
Bjarne   from Denmark
Danny Richie
Re: LS-9 in Denmark
« Reply #1 on: 12 Nov 2012, 02:07 pm »
Welcome to AC.
I don't know of any LS-9's in Denmark off hand.
tubesaab
Re: LS-9 in Denmark
« Reply #2 on: 12 Nov 2012, 03:09 pm »
Thanks for the welcome
pitty that no one in Denmark have build it
if i order from USA i have to pay 37% in tax--not so good
there for it was nice to hear them first
have you compare LS-9 to other higend speakers,,(name)
right now i use a PEAK-CONSULT EMPORER speaker
best regards
Bjarne
Erpeder
Re: LS-9 in Denmark
« Reply #3 on: 12 Nov 2012, 03:29 pm »
Hello
best regards
Bjarne   from Denmark
Hi Bjarne.
I know there are a pair V1 bass system: Dual GR 12-16 woofer and Rhythmik 370 servo amp. Main speakers a combination of ribbon and planar unit. It is in my home.
tubesaab
Re: LS-9 in Denmark
« Reply #4 on: 12 Nov 2012, 04:11 pm »
Hi Erpeder
where in Denmark do you live--like very much to hear that system
best Bjarne
Erpeder
Re: LS-9 in Denmark
« Reply #5 on: 12 Nov 2012, 05:28 pm »
Hi Erpeder
best Bjarne
Ok. I live in Herfølge. Rght now my sub box is the W- baffel design. Next year I will make a H- baffel with a sand sandwich. 16 mm. mdf. 20 mm. sand and then 16 mm mdf. There are lot of vibration. Maybe you have read about the ribbons on hif4all.dk and Nedrs.dk. It is Andre`and mine project. The V1 bassystem is the absolute best a have used together with our ribbons. We have make a lot of experiment with the 370amp. with it`s ovn preamp, and bypassed it, and used digital X-over and back agin. First I think it was bad with the digifilter, but after some adjustment the digifilter is the best, and I still use the servo.
tubesaab
Re: LS-9 in Denmark
« Reply #6 on: 12 Nov 2012, 05:34 pm »
Hi Erpeder
Typical--i live in west Denmark,,can not be more far away
I think that i have seen something about the ribbon,,
can you give me the link to them
best Bjarne
Erpeder
Re: LS-9 in Denmark
« Reply #7 on: 12 Nov 2012, 05:54 pm »
Hi Erpeder
best Bjarne
200-300 km. Actually we have some demos for sale in Nerds and H4A right now in the markers place.
Here is it the link the tread.
http://nerds.dk/board/viewtopic.php?f=8&t=281
