Front Baffle Thickness for N3 & N3s
0 Members and 1 Guest are viewing this topic. Read 1271 times.
Ed VB
« on: 11 Nov 2012, 03:57 pm »
Danny
If building the enclosures would a 1" or 1.125" MDF be better for the front baffle of the N3 & N3s or there is no differance using 3/4"?
I can get 1.125" MDF stair bullnose that is 11" x 48" locally here so just wondered if that would be a better way to go if building these.
If 1.125" is better what size radius on the backside would you go with for the woofers?
Danny Richie
    • http://www.gr-research.com
Re: Front Baffle Thickness for N3 & N3s
« Reply #1 on: 12 Nov 2012, 02:04 pm »
You can go with a thicker front baffle if you want. The gains with the N3 will not be as great as with speakers that have woofers that are counter sunk requiring a lot of baffle thickness be milled away. Since the N3 woofers surface mount you don't loose baffle thickness. Also, metal frame woofers tend to transmit a resonance to the front baffle easily, so thicker baffles really help reduce that. The N3 woofers use a non-resonant polymer frame so it is not as much of an issue.
Just be sure that as the baffle thickness increases that you add a larger and larger radius on the back side of the woofer hole. The bigger the better.
