ANN: HpW-Works V3.2 Spectrum Analyzer & Wave Generator
0 Members and 1 Guest are viewing this topic. Read 1676 times.
hpw
Version 3.2
Supported MS Windows versions:
- MS Windows XP, 32 bit & 64 bit with WoW64 mode enabled
- MS Windows Vista, 32 & 64 bit with WoW64 mode enabled
- MS Windows 7, 32 & 64 bit with WoW64 mode enabled
- MS Windows 8, 32 & 64 bit with WoW64 mode enabled
New in this release:
- Help: A "Beginner's Guide" book
- Various tutorials
- Input Amplitude calibration, / level / impedance / dBSPL / external gain
- Amplitude meter with additional dBV, dBmV, dBuV, dBu, dBW, dBmW, dBuW, dBc, dBSPL, Volt, Watt, % FS levels
- FFT Level Spectrum with additional dBV, dBmV, dBuV, dBu, dBc, dBSPL Y-axis scaling
- Power Spectrum (PSP) with dBFS, dBW, dBmW, dBuW, dBV^2, dBu, dBc Y-axis scaling
- Power Density Spectrum (PSD) with dBFS, dBV^2, dBc Y-axis scaling
- FFT / PSP / PSD with cursor x/y position toolbar (right click to alter between "spectrum data" or "grid position")
- Cursor data toolbar: Spectrum data or grid position related (right click on toolbar to alter)
- Main Form: Memory channel count on status bar
- Description frame, color or transparent mode
- High performance flat top FFT Windows functions (HFT70, HFT95, HFT90D, HFT116D, HFT144D, HFT169D, HFT196D, HFT223D, HFT248D)
- Wave file & Text file rewind toolbar button
- Wave file extensible format support
- Wave Generator: New Jitter with symmetric J-Test signal (J. Dunn)
- Wave Generator: New IM SMPTE & DIN waves
- Wave Generator: New HpW-Works ".hpw" wave file extension introduced. Special stimulus files for the "Wave File Sequence" with automatic configuration
Software:
- Evaluation Software with 21 trial period with the complete feature set as the commercial release ($300).
- FreeEdition with limited feature set.
Web: http://www.hpw-works.com
