James, 2 pair JBL Everest's with Eight 28B's!
0 Members and 1 Guest are viewing this topic. Read 6920 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 10 Nov 2012, 10:12 pm »
Recent install by one of our USA Dealers
james
Elizabeth
Re: James, 2 pair JBL Everest's with Eight 28b's!
« Reply #1 on: 10 Nov 2012, 10:33 pm »
The private electrical substation to power them is just around the corner....
Picking my jaw off the floor...
srb
Re: James, 2 pair JBL Everest's with Eight 28B's!
« Reply #2 on: 10 Nov 2012, 10:56 pm »
Does it have any dynamic range capability?
Out of curiosity, how does a speaker with 2 X 15" LF drivers (that isn't open baffle) only have a response down to -6dB @ 45Hz and - 10dB @ 32Hz?  Am I going to have to add subwoofers to these?
Laundrew
« Reply #3 on: 10 Nov 2012, 11:38 pm »
Why purchase only two when you can afford four :wink: Simply awesome :thumb:
Be well...
mike678
« Reply #4 on: 11 Nov 2012, 05:30 am »
I am the guy that installed that stack. We are using the upper Everest's as the woofer section of the WTMW array. So, we are "only" using 6 of the 28BSSt2. The crossover is active, and DSP is used to do the time delays and various eq's to get the speakers to act  sound as one unit. I do the fine tuning using a number of acoustic recordings and just tune for flavor and texture to the clients taste.
Elizabeth, you are right, there is a massive sub panel  around the corner with an industrial/lab grade toroid in it. The cable feeding everything is 4ga wire, with the 12 ga tapped off for the receptacles. System is kept balanced throughout.
There is a wonderful effect with this stack of speakers; the use of the upper woofers with the bottom ones provides active cancellation of the room mode at 18 to 26 hz. So, one can go up and down in volume and the room doesn't load up. The upper woofer is shut off at 300 hz; its just for the bass and sound staging. The upper woofer also provides varying levels of cancellation of other room modes, which simplifies the eq solution (the simpler, the better).
With these amps, the Speaker stack does extremely fast attack and great decay on bass. The mid-range is very focused, with tons of layering and, of course, micro and macro dynamics.  It's quite fun to play big band and other dynamic music.  Blues recordings are just...shocking.
Steve, the JBL spec on the bass is in open air; in a room you usually have to turn the 20 hz DOWN as with room gain you actually end up having too much.
There is a rug, with a heavy felt underneath, that is rolled up for this picture, that occupies the space in front of the listener.
Laundrew
« Reply #5 on: 11 Nov 2012, 02:26 pm »
I much prefer the "Olympus Mons" upgrade - who knows, if they could find cheaper labour on Mars, they would probably build them there  :lol:
Be well....
rollo
  • Rollo Audio Consulting -
« Reply #6 on: 11 Nov 2012, 04:52 pm »
    Cool install. Now not be a party pooper but me thinks he needs a larger room. Anyway a lucky person to own it.
charles
redbook
  • the music is the blood...........
« Reply #7 on: 11 Nov 2012, 04:55 pm »
 Now that's dynamic !  love it. James Lansing and James Tanner....great team :thumb: :thumb:
ec
« Reply #8 on: 11 Nov 2012, 06:07 pm »
Guess there was no more money for room primer and paint after the speakers and amps.  At least he/she has his priorities straight  :D
brucek
« Reply #9 on: 11 Nov 2012, 06:32 pm »
I'm confused why they needed so many screws in the drywall?
PRELUDE
« Reply #10 on: 11 Nov 2012, 06:36 pm »
It makes the sound better and more job for painter. :thumb: :lol:
mike678
« Reply #11 on: 11 Nov 2012, 07:41 pm »
The room is larger than it looks as it goes back quite a ways. The drywall is special acoustic-grade stuff that is quite heavy.
Yes, mudding and painting is VERY low on the list of priorities.
We went with this array because he got used to a very tall and full sound stage illusion with his previous speakers (Acapella Triolons), but he loves the dynamics and low distortion of the JBL. So, we came up with this idea as a way to have both.  I have to say it looks as if JBL had this in mind all along....you just KNOW that the guys that built them tried this out!
The 28b's kicked out all the super-expensive amps and there is nary a tube to be found in the house now.  (One pair of those amps paid for ALL of the 28bs!)
The main source of music is a server, where we are ripping and cataloging his extensive vinyl collection. The sever also has the usual assortment of red-book and hi-rez digital files.
