0 Members and 1 Guest are viewing this topic. Read 11385 times.
I sometimes get the impression that folks are just waking up to active crossover systems. You know, they've been around for many decades.
I am considering the Swiss Army knife DCX2496 to replace an analog active but this blog warns of issues when used with a tube preamp. Comments?http://redspade-audio.blogspot.com/2010/12/first-test-keith-ws-tubehorn-system.html
Yes, but I think the technology has advanced enough now that "anyone" can have a go at it, quite inexpensively. By that I include not just the high/lowpass filters but EQ as well as measuring gear.
This is true, and i've found this capability very useful. Both units i have had are not very good sounding, the analog section really needs to be replaced to make these sutable for hifi use.dave
Really? Mine is dead quiet, and sounds very good. I have considered sending it off to have the outputs altered and may do it in the future running the Maggies using the passive crossover route while the unit is being altered. I have been sufficiently satisfied that I have put this off for the time being though.
If you haven't already seen this article, it's a good read, and outlines what type of technology could be implemented a 'few' years ago. http://www.linkwitzlab.com/Removed%20pages/x-sb80-3wy.htm
Davey,I have a full set of O'Netics transformers. What differences did you note after replacement?dave
