Adding picture to my profile
0 Members and 1 Guest are viewing this topic. Read 1258 times.
DGCURTIS36
« on: 7 Nov 2012, 09:36 pm »
I asked Jim how to add a picture that would show up when I post something on the forum and he wrote back the following -
On the top level menu on audiocircle, there is an item called "profile".
> If you point to that, a drop-down menu will appear. The last item on
> the drop down is "Site Profile". If you click on that, a screen will
> come up. In the "Personalized Picture" section, select "Upoad an
> avatar". On the right, you will see a button called "Choose File."
> This will allow you to select a file on your computer. The file size should be around 80 x 80 pixels.
When I point to profile I don't get that option.  I only get "Summary" and "Account Settings", and I don't see anything like that in account settings.  Jim suggested I post my question to you all - probably an obvious answer but not one I can figure out :? :? :? from looking at help.
Soon to be part of the Salk/SS8 family Greg
JohnR
Re: Adding picture to my profile
« Reply #1 on: 7 Nov 2012, 11:56 pm »
You'll need a couple more approved posts before you can do that. Sorry for the inconvenience...
DGCURTIS36
« Reply #2 on: 8 Nov 2012, 12:07 am »
Got it - thanks!
