cheapy cheap valve amp
0 Members and 1 Guest are viewing this topic. Read 1675 times.
versus rider
« on: 6 Nov 2012, 06:47 pm »
http://www.ebay.co.uk/itm/110908915197?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
picked this up a couple of weeks back. First job was to put a good earth on it and NOT use the supplied chinese plugged lead with dodgy adaptor to UK socket as the earth did not connect to the adaptor. The wiring was much neater than the pictures on ebay and after carrying out a start up without the rectifier in, only because I was feeling a little nervous. I had nothing to worry about it works...and sounds superb, as good as anything else I have owned. 4-5w and drove some Heybrook sextets at a friends with ease, ok maybe not as much grip on the bass as a huge Sony vfet but will work well in my horn system.
