Little Fat Glider vs Giant Glider
0 Members and 1 Guest are viewing this topic. Read 3794 times.
zzzmonster
« on: 6 Nov 2012, 07:33 am »
Hi everyone, looking to get gliders for mobility of open baffle loudspeaker as well for bass isolation from marble floor
Speaker is Nao Note http://www.musicanddesign.com/NaO_Notediscus.html
The speaker is modified with a 6 inch high plywood base to increase the height and to couple the speaker.
Total weight of speaker with base is about 47 kg
Speaker base is 11 inch wide by 18 inch deep.
The speaker will always be moved (during listening 1 position, after that store it in 1 corner of the room)
So which product is more suitable and the quantity
Thank you
Herbie
    • Herbie's Audio Lab
Re: Little Fat Glider vs Giant Glider
« Reply #1 on: 6 Nov 2012, 05:14 pm »
Going by the guidelines in the product descriptions on our website, Giant Fat Gliders would be the better option. Four per speaker is best.
Steve Herbelin
Herbie's Audio Lab
zzzmonster
« Reply #2 on: 7 Nov 2012, 12:16 am »
Ok, thank you, will order as per instructed   :)
