SUB $200 USB to SPDIF converter recommendations
0 Members and 1 Guest are viewing this topic. Read 5603 times.
jarcher
  • It Just Sounds Right
« on: 5 Nov 2012, 11:12 pm »
Got a HiFace2 which I'm still breaking in, and demoing a Stello U2 96/24 USB link.  HiFace2 is more detailed but sometimes a bit too shrill - maybe needs more breaking in.  The Stello seems warmer and a bit meatier, which is more to my taste.
Any suggestions for good alternatives in the sub $200 range?  I paid $185 for the HiFace2, and the Stello is being offered to me at demo price of $200.
I'm using a Mac Mini & Bel Canto 1.5 dac.  I tried USB direct from Mac Mini to Bel Canto & preferred the HiFace2 & Stello in between.  Interconnects are Wireworld Starlight Coax & USB digital. I don't really need more than 96Khz / 24 bit honestly as there are few recordings that I want or are willing to pay for at higher resolution.
roscoeiii
Re: SUB $200 USB to SPDIF converter recommendations
« Reply #1 on: 5 Nov 2012, 11:30 pm »
The Musical Fidelity V-Link II would be worth looking at. non-24/192 version is around $130 at Music Direct.
jarcher
« Reply #2 on: 6 Nov 2012, 12:15 am »
I've often considered that one.  Do you or anyone else think it's going to sound better than the two I'm trying?  Guess I could buy & return if necessary.
Quiet Earth
« Reply #3 on: 6 Nov 2012, 12:42 am »
Actually,  the more expensive Musical Fidelity V Link 192 is on sale (clearance?) for half price, or $199 at the usual places. Maybe they are phasing it out.  :dunno:
Anyway, that one is asynchronous, and it would be a better comparison against the U2 which is not asynchronous. If you get the MF let me know what you think of it. I have the U2 over here and I sort of gave up on it after about 6 months of serious use.
Perhaps the USB to SPDIF devices that don't have their own power supply don't sound as good as the ones that do.    :dunno: :dunno: again.
srb
« Reply #4 on: 6 Nov 2012, 03:58 am »
Although it is 50% over your budget, the $299 Wyred 4 Sound uLINK available next month would be of interest to me particularly if the DAC I was using had a BNC input, but only the top of the line Bel Canto DAC3.5VB has a BNC input.  When you're trying to get everything just right, it seems like it would be nice to have a true 75 Ohm S/PDIF connection.
The uLINK is 24/192 asynchronous and can be USB or external 9VDC powered.
Ern Dog
« Reply #5 on: 6 Nov 2012, 08:26 am »
Jarcher- What music software are you using in your set up?  Just asking because every part of the chain is crucial for best results.
jarcher
« Reply #6 on: 6 Nov 2012, 04:04 pm »
Why did you give up on it & what are you using instead?  How / why do you think an external power supply helps?
jarcher
« Reply #7 on: 6 Nov 2012, 04:09 pm »
I'm trying out pure music and audiovarna plus w/ itunes w/ same settings (memory play, etc).  I want to stay w/ itunes for the moment as library because of idevice remote among other reasons (even though other software as idevice remote as well).
I think I'll end up going w/ pure music because of technical problems I had w/ audiovarna plus (skipping etc).  The technical problems I think are not wholly AV+ fault : i.e. too much stuff including music on USB drive / low memory / etc.  BUT pure music was much better able to handle these limitations w/ out as serious performance problems.  Also being able to use one license on unlimited computers (on at a time) is also nice as I would use it on multiple computer.
jarcher
« Reply #8 on: 6 Nov 2012, 04:13 pm »
I think I really want to stay at or below $200 even if I have to buy used.  Guess it's just a matter of principle that I've decided randomly that such a device shouldn't cost more than that & won't spend more.
The 192 is not as important to me now, but I had forgotten that the U2 is not asynchronous & where that is desirable as a spec, I'm wondering how important it becomes in practice.  I guess w/ the U2 it means that the mac mini is calling the clock vs the Bel Canto (?)
Quiet Earth
« Reply #9 on: 6 Nov 2012, 04:58 pm »
Sorry for the confusion. I didn't give up on the U2 specifically, I gave up on my computer as a digital source altogether. I bought a really nice CD transport and it made my computer sound so bad that I decided to just take the computer out of the system altogether and spin CDs for now. I'm gonna give "discless" another try down the road, but I think I need to start from scratch and try a different approach. Maybe the 3rd time will be the charm.  :D
I also have a MHDT Constantine USB / SPDIF DAC that I bought a while ago. When I compared the USB input of the U2 to the Constantine's direct USB input, the U2 doesn't sound nearly as good. I thought the reason might be because the U2 is getting it's power from the computer and the Constantine has its own power supply. I don't really know . . .  :dunno:
roscoeiii
« Reply #10 on: 6 Nov 2012, 05:01 pm »
What computer set-up did you use?
Quiet Earth
« Reply #11 on: 6 Nov 2012, 05:30 pm »
Apple I-mac, I-tunes, CDs ripped with error correction to AIFF, disabled all unnecessary functions on computer, Stello U2, various spdif cables
Oh and Wireworld Starlight USB cable.
jarcher
« Reply #12 on: 6 Nov 2012, 05:56 pm »
If you decide to give it another go, try using pure music / audiovarna / etc with the "memory play" option.  I found this was quite a decent bump up in sound quality at very little investment.  PM is $129 for multiple machines, AV+ I think around $59.  They have trial versions, so you can experiment w/ no cash out.
Quiet Earth
« Reply #13 on: 6 Nov 2012, 11:27 pm »
Thanks man!
Yeah, I know that one of the things I need to do next time around is to choose a different software player besides iTunes. The one you mentioned is highly regarded so its on the list.
 :thumb:
jarcher
« Reply #14 on: 7 Nov 2012, 07:04 am »
Nice thing about Pure Music, Audiovarna - and Decibel - is that they work piggybacked on Itunes. So no migration of your library, no giving up i-device remote, etc.  Audiovarna is even more invisible - but PM worked better when machine is being taxed doing other stuff, in my limited experience.
Still don't know what to do about the usb-spif converter thing - there must be other good options other than the HiFace2, Stello U2, and MF Vlink at or under $200 new or used.  Maybe just buy the MF Vlink, and make a decision between these three, and call it quits.
