Omega Super 6xrs or Hoyt Bedford Type 2 with Ampino Menuetto
0 Members and 1 Guest are viewing this topic. Read 2604 times.
batsthecat
I just got a used Dayens Menuetto and I want to get some high efficiency speakers to go with it.  My room (living room) is 22x12x7.5 and I  listen mostly to classical at low levels.  Do the Hoyt Bedford type 2 and Omega Super 6xrs have very different qualities?  Is so, could someone describe the differences?  Which one do you think would work best in my room.  I mostly listen to CDs and SACDs on a Oppo 95.
Jazzaudio
Re: Omega Super 6xrs or Hoyt Bedford Type 2 with Ampino Menuetto
« Reply #1 on: 19 Mar 2013, 10:19 pm »
Did you get the XRS or Type 2?  I've been running a Dayens Ecstacy IIb integated amp on Tekton Lores (98db, two-way with most of the sound up to about 8000kz handled by the main driver), and the sound is spectacular.  I imagine it could only be better in the crossover-less Omegas or Hoyts!
