VPI Scout platter SOLD
0 Members and 1 Guest are viewing this topic. Read 1074 times.
designdude
« on: 3 Nov 2012, 08:36 pm »
VPI Scout platter. Picked this up a few years ago from another Audiogon member who had upgraded his platter. Used but in good condition. Some minor chips on the lower edge (from when it was dropped during a move).
Included is the platter, and a complete inverted bearing assembly. (The bushing on the platter is a ½” diameter, and will easily spin on any ½” spindle.) Also included is a VPI buna-N-rubber belt in excellent condition. It was purchased new from Music Direct in April of 2010.
Note: the threaded post on the top side of the spindle is slightly bent. The spindle is still accurate, but the threaded portion is not perfect. If you use a weight based clamp it’s not a problem, but if you use a threaded VPI clamp it doesn’t seat perfectly flat. You could probably tweak the threads if you wanted, but I wanted to mention it.
SOLD
I have used this platter with a number of custom turntables I’ve assembled. You can see them on the album titled Turntable Chronicles on my flickr account:
http://www.flickr.com/photos/designwizard/collections/72157626096393626/.
 You can also see detailed pictures of the platter and parts as well.
« Last Edit: 12 Nov 2012, 12:05 am by designdude »
