I use MOG and a Squeezebox Touch - Would the Re-clocker benefit me?......
0 Members and 1 Guest are viewing this topic. Read 2175 times.
Cut-Throat
MOG streams at 320 kbps. With my Horn and SET amp system.....MOG sounds as good to me as my FLAC ripped CDs, and in some cases it sounds better, especially with the re-mastered versions available on MOG......My question is would the Mesh Re-clocker improve the sound from MOG into my Squeezebox Touch into my Electric Minimax Tube DAC?
audioengr
MOG streams at 320 kbps. With my Horn and SET amp system.....MOG sounds as good to me than my FLAC ripped CDs, and in some cases it sounds better, especially with the re-mastered versions available on MOG......My question is would the Mesh Re-clocker improve the sound from MOG into my Squeezebox Touch into my Electric Minimax Tube DAC?
Quite a few customers put the Synchro-Mesh between the Touch and their DACs.  They seem to like it a lot.  Here are some feedbacks:
http://www.empiricalaudio.com/news-and-reviews/synchro-mesh
The fact that you use compressed streams should not change this result.
Steve N.
