WTB cheapish SS preamp
0 Members and 1 Guest are viewing this topic. Read 1278 times.
sts9fan
« on: 3 Nov 2012, 02:59 pm »
Whatcha got? $500 or less.
nhpm510
  • Trading refs: A'gon, Emo boards same user name
Re: WTB cheapish SS preamp
« Reply #1 on: 3 Nov 2012, 03:04 pm »
 :duh: oops
« Last Edit: 4 Nov 2012, 06:33 pm by nhpm510 »
sts9fan
« Reply #2 on: 3 Nov 2012, 03:11 pm »
Looking for a pre-amp
jparkhur
« Reply #3 on: 3 Nov 2012, 03:43 pm »
Find a FirstWatt B1 or I like the passive Khozmo. Both under 300
sts9fan
« Reply #4 on: 3 Nov 2012, 04:24 pm »
I require gain
srb
« Reply #5 on: 3 Nov 2012, 04:46 pm »
Don't know what features you need, but the Parasound Halo P3 is a nice preamp in the $400 to $500 used range.  Balanced outputs, one pair of balanced inputs, phono stage, remote control and pretty good build quality.  I don't have one for sale, but there is one currently listed on Audiogon.
jarcher
  • It Just Sounds Right
« Reply #6 on: 3 Nov 2012, 07:00 pm »
Got a B&K Pro 5 pre-amp that I would part with for $150. Original owner, almost no use last 15 years.  Does work well - have tried it out recently.  Decent phono stage.  Totally manual (no remote volume).
Don't know how low you wan to go - nice ring to that.
I also have an Anthem AVM30 processor I'm asking $500 for : would work well as a preamp (and for home theater if you wanted that extra). It's listed at the AC trading post
http://www.audiocircle.com/index.php?topic=110604.msg1142134#msg1142134
PM me if interested.
If your budget allows I'm suspecting that Parasound P3 would be the best preamp unit for the $, although my AVM30 would be close & give you nice extras.
genjamon
« Reply #7 on: 3 Nov 2012, 07:46 pm »
I have an Acurus L-10 pre with some caps upgrades and a direct soldered power cable I might be able to let go. It hasn't seen any use in a long while. I haven't looked into going rates for these kind of units, but several years ago it would have gone for $250ish, I think.
sts9fan
« Reply #8 on: 4 Nov 2012, 12:19 am »
Found!
