0 Members and 1 Guest are viewing this topic. Read 8947 times.
One of Brian's test recordings with a 30 Hz bass tone was amazing: no bass over hang, solid and the type that hits you in the gut. I played a recording with a 25 Hz tone and it was as clear and powerful as the 30 Hz tone. So, Scott Mayo, rest assured when tuned properly, the low bass is amazing!!!!! Then there is the midbass; so tight and punchy. Plucked double bass sounded just as it should. Nothing lacking that I can hear yet.
WooHoo! They finally arrived and Brian, Jim Romeyn and team were there to install and tune them. I am sure glad Brian was there to tune them. I can see why people unaccustomed to tuning VMPS speakers would have problems getting them to sound their best. It was amazing to watch Brian do his thing and so quickly. Fortunately there were few problems with the room acoustics without any room treatments. Both Brian and Jim commented that this was the best residential set-up they had heard the RM/ ...
Now, this is where this gets confusing for me -- you removed putty from only one speaker? My engineering mind can't take not having balance! Also, how hard is it to passively biamp? I have an extra two amps of amplification, so what I did was biamp my center channel with one of them (and another amp previously used for the CC). However, I'm thinking that it might be better to give the RM40s the power instead of the RM30C. This would mean that I'd have my Jeff Rowland on the uppers/mids of the RM40s ...
Hi Brian,I was under the impression that you only took putty from one PR and not the other. Thus, my confusion. Redbone,Do you have your RM40s passively biamped? If so, did you use anything to make up the difference between the amps? Couldn't the speaker level controls be used to take care of this difference? I know that an outboard crossover is the way to go, but I'm trying to be cheap for now (I just moved into a house that's costing me way more than I though it would). I would just need ...
I think for the first time, I pay no attention to the equipment and just listen to the music. It all seems to be there, and nothing draws my attention away from the musical performance. I have a bunch of cables that I had planned to switch in and out...now, why muck it up? QuoteDoes this mean you have cables to sell? I'm about to buy the RM/X and an amp, and, well....
