DSD Samples
0 Members and 1 Guest are viewing this topic. Read 3679 times.
jtwrace
    • TIPP YouTube Channel
DSD Samples
« on: 27 Oct 2012, 11:17 am »
I'm sure there are and have been posted somewhere so please forgive me.  Where can I grab some DSD samples from?  Oh some good stuff not elevator music like most of it.   :duh:
ted_b
Re: DSD Samples
« Reply #1 on: 27 Oct 2012, 01:41 pm »
By samples, you mean free?  Blue Coast has a bunch, especially if you sign up for Cookie's newsletter.  And there are servral on 2L's test bench (sourced from 24/352.8k).
http://bluecoastrecords.com/free-downloads
http://www.2l.no/hires/index.html  (15 DIFF files at the bottom of the page)
jtwrace
Re: DSD Samples
« Reply #2 on: 28 Oct 2012, 12:50 pm »
Yes.
Thanks.  I was hoping to find some rock that I could compare to my other formats.
sauroposeidon
Re: DSD Samples
« Reply #3 on: 4 Nov 2012, 05:02 pm »
Thanks. I was looking for some DSD files to use so I could play around with configuring the outputs on my computer. I'm currently trying to find someone to back up some SACDs for me. A moot point if it isn't going to sound good.
Atlplasma
  • Just off the boat
Re: DSD Samples
« Reply #4 on: 4 Dec 2012, 12:00 pm »
Just curious about something. I download a free sampler from Channel Classics that included a DSD file. It plays on Bifrost DAC, which does not support DSD. I'm assuming that Pure Music is automatically down rezing the file to 24/192. Is that correct?
ted_b
Re: DSD Samples
« Reply #5 on: 4 Dec 2012, 02:02 pm »
Ys, most likely.  You imported it to PM as a DSD file?
Atlplasma
  • Just off the boat
Re: DSD Samples
« Reply #6 on: 4 Dec 2012, 03:31 pm »
Yes. And iTunes shows the data rate at 2822.4 khz. Now, if I could only swing that Sonore DAC...  :lol:
