Hifiman HE-Adapter for less noise?
0 Members and 1 Guest are viewing this topic. Read 2830 times.
Audioclyde
« on: 27 Oct 2012, 01:31 am »
I would like to drive my Audeze LCD-2's from the spkr taps of my amps (Mastersound Compact 845 SET, or alternatively my TBI Millenia); unfortunately with either I get lots of noise/hiss. I've read that using the Hifiman HE-Adapter might reduce the noise (as well as provide protection for the amp & cans).
Does anyone have any experience/thoughts?
Thanks in advance!
Randy
victor_cc
Re: Hifiman HE-Adapter for less noise?
« Reply #1 on: 19 Apr 2013, 08:31 pm »
I ordered the Millenia to drive headphones exclusively: hifiman HE-6 and Fostex T50rp Paradox.
Jan from TBI sent me a couple of resistor network schemas (similar to the he-adapter) to drive them properly.
If you are interested I will put the schemas here.
Cheers
[email protected]
« Reply #2 on: 21 Apr 2013, 02:52 pm »
I use the adapter with a 300b set and a large 150 watt hybrid amp.  It works well and there is no noise at all.  You definitely need the resistors for a tube amp that is transformer coupled or you can damage the amp.  You can use another design, but the he adapter is pretty reasonable for getting started.
Gary
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #3 on: 22 Apr 2013, 06:12 pm »
As said before, DIY is a good option:
http://sound.westhost.com/project100.htm
Basically, an adapter prevents the amplifier from doing something bad to the headphones. You can vary the size of resistors depending on the amp output.
