SounsScape 8 open back interior.
0 Members and 1 Guest are viewing this topic. Read 2221 times.
ricardojoa
« on: 26 Oct 2012, 06:12 pm »
Hello folks,
many of us has seen the pictures of any soundscape or the SS 8  but i dont recall seeing the interior of the open back.
Can any of those who own one of the SS 8 take pictures of the interior or discribe how the interior look ? Like , is the interior venneer or it it finish with blacl sealent or whatever they are?
Thank you in advanced.
Big Red Machine
Re: SounsScape 8 open back interior.
« Reply #1 on: 26 Oct 2012, 06:59 pm »
black at the outermost edges and then raw mdf inside.  not an issue with all grill options (open and closed).
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« Reply #2 on: 26 Oct 2012, 08:40 pm »
ricardojoa
« Reply #3 on: 26 Oct 2012, 09:32 pm »
Wow, greatly apprecuated the response and the pictures.
Is is correct that the open back can be configured into a sealed mode? If so, how tightly does the grill hold in place?
Big Red Machine
« Reply #4 on: 26 Oct 2012, 09:51 pm »
Magnets hold the solid grill.  It's a midrange.  How tight do you think it has to be?  What is the concern?
pstrisik
« Reply #5 on: 26 Oct 2012, 09:54 pm »
You're welcome.  You get two grills for the back.  One is with grill cloth over an open frame, the other is grill cloth over a solid piece.  They are held with magnets to the inset ridge very tightly.  In fact -- a suggestion for Jim if you're reading --  it would help to add a thin nylon tab coming from the back of the grill frame so the grill can be pulled out more easily.  (That's how tight it is!)
.........Peter
Big Red Machine
« Reply #6 on: 26 Oct 2012, 10:16 pm »
I put my own tabs on with a stapler.
ricardojoa
« Reply #7 on: 26 Oct 2012, 10:37 pm »
Thanks for the input guys.
pstrisik
« Reply #8 on: 26 Oct 2012, 10:49 pm »
I've been planning to do that for weeks now!  :oops:
Thought it might be a nice touch to come with though.
........Peter
Austin08
« Reply #9 on: 26 Oct 2012, 11:19 pm »
I am using the open frame grill and never really bother to swap out for solid one. I like how the SS8 sounds that way.
jd3
« Reply #10 on: 26 Oct 2012, 11:40 pm »
I occasionally swap between the open and solid back grilles (I usually leave the open ones on).  The solid ones are tough to get off.  Good idea on adding tabs.
