Mah new Synergy Control Amp!
0 Members and 1 Guest are viewing this topic. Read 2687 times.
Opus Flatus
« on: 21 Oct 2012, 03:32 am »
Listening right now and it is suhweeet! Sounds like I'm in on the recording session with Buddy Guy and Junior Wells. This amp sounds allot like my beloved U70.  :thumb:
JerryM
  • Where's The Bar?
Re: Mah new Synergy Control Amp!
« Reply #1 on: 21 Oct 2012, 03:11 pm »
Sweet; congrats!  :beer:
mca
« Reply #2 on: 21 Oct 2012, 03:43 pm »
That is a cool system! At what distance do you listen?
avahifi
    • http://www.avahifi.com
« Reply #3 on: 22 Oct 2012, 09:38 pm »
I just finished turning a client's Insight+ Double 240 amp into a Synergy Double 240 amp today and it is driving my 84dB sensitivity Salk HT3 speakers surprisingly well. It behaves like it has twice its rated power.
This upgrade is really an interesting project - - - just add the complete new Synergy regulated power supply module with its own internal heat sink and regulator board.  It provides four more high current regulated power supplies for the output transistors and provides a rock solid reference for the audio boards existing regulators too.
As now the output transistors and audio small signal transistors are all running from the lower voltage regulated supplies rather than the higher voltage raw supply rails, the entire amplifier runs cooler.  This means even better long term reliability and durability, and the basic amp designs were really bulletproof even before.
Frank Van Alstine
kc8apf
  • Are you sure what side of the glass you're on?
« Reply #4 on: 22 Oct 2012, 09:54 pm »
That wouldn't be my 240/3 would it?
avahifi
« Reply #5 on: 22 Oct 2012, 11:35 pm »
Sorry, not yours yet.  The one I finished today is the 2 channel version.
Frank
kc8apf
« Reply #6 on: 23 Oct 2012, 01:10 am »
Darn. I'll have to suffer for a while longer.
Opus Flatus
« Reply #7 on: 23 Oct 2012, 05:11 pm »
MCA
Sorry for the late reply  - I listen nearfield. My house was built in 1890; so the rooms aren't terribly big and the finishes are all hard. This works best for me without having to acoustically treat the room.
Frank
Very cool post on the Synergy upgrade from the Insight+ amp.
