0 Members and 1 Guest are viewing this topic. Read 3184 times.
Does your explanation of the switch on process mean that the H+ and B+ need to be switched on at the same time...
... as I have switched on the B+ 15sec after the H+ and the LED did not change colour.
As there is now no delay in the B+ as it is coming straight from the lab supply, if I were to switch them both on simultaneously would the B+ damage the valves as they are not at the correct temperature?
