NO LONGER AVAILABLE
0 Members and 1 Guest are viewing this topic. Read 809 times.
Chipbyrd
NO LONGER AVAILABLE
« on: 19 Oct 2012, 11:52 pm »
SOLD SOLD SOLDThis is a remarkable cd player and a great standalone dac.  It is about 2 years old, but it is in pristine condition.  I will double box with original packaging.   Asking $800.00
Here’s some info from the website:
Azur 840C Black Fin DSP upsampling CD player Features.
Adaptive Time Filtering (ATF) asynchronous up-sampling technology converting 16-bit 44.1 kHz CD data to 24-bit 384kHz
32-bit Analog Devices Black Fin DSP
Dual differential DAC configuration using high-end Analog Devices AD1955 DACs
Fully differential anti-aliasing topolopgy based on linear phase Bessel filters
DC servo circuitry with no capacitors in the signal path
Two digital inputs allowing up-sampling and playback of other sources
Digital outputs allow recording of up-sampled audio
Control Bus In/Out, IR emitter in and RS232 for easy multi-room compatibility
Extruded aluminium side panels and solid aluminium front panel plus an ultra rigid, acoustically dampened chassis
Navigator style Azur remote control which also controls Azur amplifiers
Here’s a couple reviews:
http://www.theabsolutesound.com/articles/cambridge-audio-azur-840c-cd-player/
http://www.cambridgeaudio.com/assets/documents/Hi-FIChoiceNov06840Clicensedreprint.pdf
« Last Edit: 2 Nov 2012, 03:55 pm by Chipbyrd »
