Lowther phase equalizer
0 Members and 1 Guest are viewing this topic. Read 2186 times.
cafyon
« on: 17 Oct 2012, 03:45 pm »
Hello,
You know Lowther's phase equalizer plug. I'd like to diy it. Where can I find scaled drawing of it with measurements or a 3d model?
Scott F.
Re: Lowther phase equalizer
« Reply #1 on: 17 Oct 2012, 04:24 pm »
I'm not sure one exists, or let me put it this way, I've not seen one.
I've got the stock one on the PM2As and a pair that are longer. It definitely changes the sound when you swap them out. After playing with both, I've settled on the stock pair. They seem to sound more natural to my ears.
Good luck in your search  :thumb:
cafyon
« Reply #2 on: 19 Oct 2012, 03:32 pm »
thx for the info
maybe an owner of this new phase equalizer help with its dimensions. measure & post, i mean  :D
i assume the dimensions as follows wrt its image:
base, mounting to front of driver: 36mm
widest section: 60mm
depth of this section: 5mm
holes: 8 x M9, equally spaced
depth of base: 15 mm
front diameter: 34mm
depth of each conical section: 20mm
total depth: somewhere between 52 to 60 mm
any help?
