0 Members and 1 Guest are viewing this topic. Read 7124 times.
I'll agree. Placing 2x4x3" acoustic foam in front of a TV made a noticeable improvement in my former set up.
Hey Austin, what kid of diffusers are those there?
With my Dipoles I tried absorption behind, I ended up with a QRD diffuser instead, thismade the imaging incredible.
I'm amazed that you would be getting that bad of stuff from the TV with the speakers so far out in front of it. To really know if the diffusers solved a problem with the TV you would need to listen first with TV and then without TV, in both cases with no diffusers.It's possible that with NO TV a similar improvement might be noted when putting treatment in that area.Rod
