SOLD: Coincident Statement Phono Preamplifer, PRICE REDUCTION
0 Members and 1 Guest are viewing this topic. Read 4375 times.
Hear Clifford Brown
$3,800 plus shipping from 98332.
I’m the original owner, purchased in April 2010, and selling because now using an integrated.  Mint condition with no scratches or swirl marks on the stainless steel finish.  I used this as phono and line stage, it has two inputs, phono and line for CD, SACD or other source.  Original tubes, which are reissued Mullards (12AX7).
Original box and packing in very good condition.  Triple boxed; outer is 15 x 21 x 23 with two inner boxes, one for power supply and one for preamp.   Power supply weighs 40 pounds, preamp 17 pounds and box/packing 8 pounds.  Includes owner’s manual, power umbilical between power supply and preamp, but no power cord.
Buyer to pay actual shipping, and PayPal fee of 3%.  I'm in the Seattle/Tacoma area.
See my positive feedback on Audiogon under Jeff_ss.
Additional pictures are available.
From the concluding remarks in the Stereomojo review:
It is called the Statement because it is just that; a no compromise, state of the art Statement as to how great phono playback can be, plus you get the luxury of a very fine line level input to boot that's probably worth the cost of the unit all on its own - it's that good! If you only have a turntable and a digital source, you need nothing more.
From the Coincident website:
The Coincident Statement Phono Preamplifier is a high gain, all tube unit employing the highest quality MC step up transformers to accommodate virtually all moving coil cartridges.  Due to employing only 2 all tube gain stages, high gain is achieved with ultra low noise and the absence of microphonics or hum.  The RIAA curve is passive, zero feedback utilizing the closest tolerance resistors and polystyrene capacitors to obtain accuracy of less than .1 db deviation from 20hz – 20khz.  All coupling capacitors are the finest and most expensive Teflon Film and Foil.
The 66 db overall gain coupled with low output impedance and the use of the finest discrete resistor mono volume pots allows the Statement Phono Preamplifier to be directly connected to an amplifier without the use of a line stage.  The inclusion of a line input, selectable by a front panel toggle switch, can accommodate a CD/SACD player or any other component, thereby obviating the need for a line stage.
There are no circuit boards or connecting strips to degrade the signal transfer or deteriorate over time.  Everything in the Statement Phono Preamplifier is hard wired with the shortest signal paths possible.
The separate power supply has enough capacity and energy storage to power a 100-watt amplifier.  There are separate transformers for the high voltage and low filaments.  Furthermore, the high and low voltage sections have independent choke and large capacity filtering.  All power supply capacitors are the finest sounding, highest quality polypropylene.  The power supply is the highest standard possible and provides the foundation for the Statement Phono Stage.
The build quality of the Statement Phono is the finest available.  It was designed with no cost restraints and the highest priority placed on sonic performance. It represents an all out assault on the state of the art.
Specifications:
Frequency Response: 10hz – 25khz +/- .1 db
Gain: 66 db- MC
Output Impedance: 250 ohms
Maximum Voltage Output: 30 V
Impedance: 3-10, 11-30, 31-100, 101-300 – MC
Phase: In phase
Dimensions: 203mm x 260mm x 390mm – Power Supply and Phono
AC Voltage: User Selectable – 115V or 230V
Tubes- 4-12AX7- Reissued Mullards are included
User Features:
Finest Discrete Resistor Dual Mono Volume Pots - Allows for Direct Connection to Amplifier without the Use of a Line Stage and corrects for channel imbalances
Dual Pairs of RCA Outputs- Allows for Biamping
Impedance Selector-Optimizes all moving coil cartridges
Mute Switch – Conveniently mutes signal when changing records
Lift AC Ground - Conveniently breaks AC ground to eliminate hum caused by ground loops
« Last Edit: 27 Oct 2012, 05:07 am by Hear Clifford Brown »
roscoeiii
Re: FS: Coincident Statement Phono Preamplifer
« Reply #1 on: 16 Oct 2012, 12:26 am »
price?
jtwrace
    • TIPP YouTube Channel
morganc
« Reply #3 on: 16 Oct 2012, 07:49 pm »
He has the ad on AudioAsylum listed at $4000.  I PM'd him a ? and he responded quickly.   I had the Conicident Amps and really wish that I still had them.  I have heard the Pre is even better than the amps........
Hear Clifford Brown
« Reply #4 on: 24 Oct 2012, 02:24 am »
bump
