Ncore build questions.
0 Members and 1 Guest are viewing this topic. Read 1999 times.
DaveX
« on: 15 Oct 2012, 04:22 pm »
Hi Chaps, If you connect a safety earth on the mains inlet to chasssis should I still connect pin one of the XLR to the chassis, will this not cause a hum loop. Bruno's datasheet shows no safety earth for balanced operation.
I intend to wire up the Nampon, please tell me if this is correct. Use a SPDT ON-OFF toggle switch, solder the Nampon wire to one tag of the SPDT, connect the other tag to chassis.
The NC400 module shows 5 tags to the right of J7, :banghead: anyone know what they are for. Thanks.
« Last Edit: 15 Oct 2012, 04:24 pm by jtwrace »
srb
Re: NCore build questions
« Reply #1 on: 15 Oct 2012, 04:36 pm »
At first read I thought Hypex had added a new amp to their lineup called the "Encore"
NCore®
