Sorbothane Pandafeet w/ Panny digital amps
0 Members and 1 Guest are viewing this topic. Read 1314 times.
Red Dragon Audio
    • http://www.reddragonaudio.com
« on: 11 Jun 2004, 06:08 am »
Has anyone already tried using these http://www.pandathumbaudio.com/pandafeet.htm">sorbothane footers on digital amps like the panny XR45?  If not I am going to try some of the blue footers under my 9.2lb XR45.
I will place a DIY bag of lead shot/sand on top of the amp or some heavy wood so the footers will be optimally loaded at 20-25lbs or so.
Any thoughts, theories, ideas?
Red Dragon Audio
« Reply #1 on: 14 Jul 2004, 05:59 pm »
Well I have had the Pandafeet (blue) under my XR45 for a few weeks now and I haven't wanted to take them out.  The Pandafeet are placed evenly under the four corners of my XR45 and I have a bag of lead shot on top of my amp to load them properly (I will switch to sand when I have the time; the lead shot was just here on hand so I used it).
I think the differences were subtle under the amp but positive.  If you have ever used Sorbothane style footers under your Source or speakers you will be familiar with the benefits of this great material.
PROS:
-Even more silence between quiet passages.   (blacker background which surprised me as the Panny is already a champ in that area)
-Midrange feels a wee bit more relaxed & open.
-Bass is still tight and firm which is a product of the amp itself but the footers did nothing to hurt the bass which is a good thing.
-Highs were just a touch smoother (very slight but noticeable)
-With a 30 Day Money Back guarantee...it's a no brainer to just try these out.
CONS:
-Sorbothane can ruin the finish on wood surfaces and other things as well.  If you want to avoid this, just put small pieces of wax paper on both ends of the footers.
-People who own heavy amps (generally tube amps are quite heavy) will have to purchase two sets because they only support a certain amount of weight.
-They don't magically take themselves out of the package and jump under my equipment. ;)
So for $20 and a $2.00 bag of sand for proper loading, I have found a good way to isolate the digital circuits in my XR45 and make subtle improvement on an already excellent budget amp.
I would highly recommend this product to anyone looking to isolate their amps, DAC and/or transports/CDP's.  Folks with sensitive tube gear could really benefit from these feet .
PSI tried these footers under my transport and everything I mentioned above was even more true and apparent (seems transport mechanisms are more suceptible to vibrational engery...big shock there I know  :roll: )
gary
« Reply #2 on: 14 Jul 2004, 06:33 pm »
I'm glad you're happy with the footers :)
Thanks for posting
Gary
Red Dragon Audio
« Reply #3 on: 14 Jul 2004, 09:38 pm »
Quote from: gary
Thanks for posting
Gary
I'm very happy with the footers as is my friend (he bought one of the three sets I had purchased from me).  He has his set under his transport and says it's way better than the rubber/cork/rubber footers he was previously using.
